rubrduk
- Oct 10, 2020
I keep the JNC Air round as my goto, it's a battery jump-pack with an air-compressor
cloreautomotive.com
I heavily researched jump/compressors and I kept finding the JNC units being highly rated, they also have a 1-time free battery replacement.
I've had mine for just more than a year and it's been flawless
I specifically wanted this type of unit because I use it for my travel trailer, camping, and as a general-purpose stand-alone rescue device.
I can say that topping off the RV tires @ 65psi takes some doing,...is slow as to be expected from a portable, battery device, but 0-30psi in a truck tire is no problem.
it also easily charges from the 115v AC outlet in the truck without blowing fuses (it's a low draw)
final note: if you off-road occasionally, this will serve you until you fully commit to an onboard system and will also be an excellent rescue device and all-purpose inflator.
JNCAIR 1700 Peak Amp 12V Jump Starter w/ Air System - Clore Automotive
Get portable power to start cars and inflate tires with the JNCAIR 1700 Peak Amp 12 Volt Jump Starter with Air System from Clore Automotive. JNCAIR 1700 Peak Amp 12 Volt Jump Starter With Air System
