Darksteel165
I have air suspension.Tried again last month…and failed again. The Oil Udder did great at catching the initial oil spillage. But there’s just not enough room to get the filter out without turning it fully sideways, and that’s not possible until the Oil Udder is out of the way. So I’ll go back to the slightly-less-messy two-bag method.
I fully acknowledge that you all may have figured out a trick that I haven’t. Or am I experiencing a worst-case scenario with 4WD, air suspension, and Off-Road Group?
I put it on OR2, not sure if it matters.
On the way down to make it easier you can pop out a christmas tree push clip and bend some wires (they are sturdy).
Make sure you are wearing gloves so you don't bang up your hand, it is a tight fit but you can get it down in the normal upside down position even without popping out the clip (I left my clip not connected as the cables are tight anyways)
It is even harder if you use an SRT filter like me, I had to upgrade to the XXL version as the XL was almost the exact size of the oil filter, meaning it was useless except as a grip.
