Oil pressure range?
I'm not saying I agree with it, but the manual says 4 psi minimum at idle. Just scroll all the way to the very bottom, page 12.
Do not run engine if at zero but 4 psi is OK🤣
Just did an oil change with mobile one 5w-20 extended performance full synthetic. Used the Fram 20k mile oil filter this time (Fram XG10060). Last oil filter was a wix XP 57060 XP.
Sitting here just idling getting the oil up to temperature shocked when it said 55 PSI on startup 😂
Typically on idle I run around 33-39 PSI depending how cold/warm it is outside and how quick it gets to temp.
Idling outside temp 52°F
160°F at 46psi
180°F at 40psi
185°F at 39psi after 12 min at idle
192°F at 37psi after 16 min
199°F at 35psi after a full 20 min of idle. Trans temp 159°F. Seems all within the tolerances and seems to be healthy. 25,500miles. 2019 Ram Rebel oil changes done between 5000-6000miles.
Just got to check engine light pulled the code it was a low oil pressure light and my oils at 26 PSI at normal operating temp I'll post a picture I'm a little worried cuz I just got it back and they just replace the computer or other issues I'm also getting a couple other codes too p1254 p0057b and one about the air dam but I just pulled them again and a brake pedal position something or other. But the oil one has me worried I only got 60 miles on my warranty
How many miles on the oil? What kind of filter? I would start by changing the oil and using a Mopar filter. Current filter might have partial or small obstruction.
