immersivenc
- May 16, 2018
Really hoping this is just some extra assembly oil weeping out. I noticed this the other day and wiped it and there is more there now.
Between the trans bellhousing and engine? I have heard about extra assembly lube coming out near that area for the first bit and it does look a little dark to be oil. Definitely keep an eye on it and if that spot keeps getting wet you'll want to take it in to get looked at.
Since many of you have 4th Gen Hemi experience, is it a leak-free engine as any modern one should be? I was just assuming they would be.
Dealer cleaned the spot before I picked it up and told me it was just residue. It was squeaky clean when I picked it up, I crawled under it and looked. Now... this a few days later. I believe this to be a rear main seal leak. Case reopened with FCA, emails off to dealer mgt and we're back to the service dept. Again.
Looking at your photo it seems odd that if the rear main seal was leaking you'd see something coming out of the weep hole. But it looks dry in the picture.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 002491 miles.
Yes, unlike 2 BMWs, my 3 HEMI vehicles have all been free of any oil or transmission leaks, and I sold all of those around the 7/8 year mark still leak free.
I just noticed this afternoon that i have some residue in the same location. How did the dealer end up handling the issue?
I fondly remember those little cans of grease for the M1 Garrand and M1 Carbine.
I'm not sure I can offer much except to advise you that the transmission fluid used in the 8 speed series (8HP70, 8HP75, 8HP90, and 850RFE) is a greenish-yellow color. It is NOT red. Whether that's what you're seeing or not I can't tell. My recommendation is to have the service department inspect and note about this on an invoice for the record.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 010831 miles.
Picked up my truck last week and had it on the lift at work for a squeak i have in the front end and looks like i have the same leak.View attachment 23273
