OIL consumption
Engine burn the oil
  • Yes
    Votes: 1 20.0%
  • No
    Votes: 4 80.0%
  • Total voters
    5
EugeneYYZ
Toronto
Hello fellas did someone pay attention how much oil you drain at oilchange , at the beginning it should be 9.5 Liters . after 8000km i got around 7.5 L to drain into measured canister .
Friend of mine got the same problem after 10.000 km , drain around 7 L down at oilchange .
My previous generation ecodiesel consumes NOTHING !
Let me know if someone noticed same problem .
Cheers
Buz
Don't forget your oil filter was full as well as all the oil that ran out while removing the oil filter.
ElkoNV
My dog thinks I’m cool.
NV
I have read several reports of oil consumption in the first 5K and then no more. Is this your first oil change?
Sascwatch
32000km at my last oil change, 10000km between them. Oil was still at the top of the dipstick.
tom318
Northern Illinois
I didn't check how much I drained for my first change but 9.5L sounds high. Is that what the initial factory fill is? My owners manual states 8.5qt or 8L for Engine Oil with filter. When I did my first oil change I put just over 8L in and its since looked good on the dip stick.
EugeneYYZ
Toronto
2 oilchanges were made by dealer at 2000km , 7000km and now i did by myself at 15000
EugeneYYZ
Toronto
Sascwatch
Here’s from the owners manual.
my dealer lists 9 litres or quarts on my invoice, I’ll have to double check.
ElkoNV
NV
The dealer might not have put enough oil in it. I would give it a couple of thousand miles, and check it before I panicked.
