Thank you. I saw the Rebels have some crazy 55 front and 45 rear recommendation for psi and started to second guess my 35. I also have 3.92 gears and still need to get the speedo calibrated.I usually run mine at 33-35 pounds, I’ve gone as low as 30 cold with zero wear issues or problems. Factory tires only called for 32 psi for reference. As for mileage I get between 22 and 26 with city and highway mixed driving. Biggest variable is how I drive. I definitely do not hyper-mile the truck but I don’t lead foot it all the time either. Double check that your speedometer was adjusted for the larger tire size in case your numbers are way off. Just a reminder I’ve got the diesel motor and 3.92 gearing.
Thanks for the help. Did you get your speedo calibrated?I've got 275/65r20s and run mine around 38-40psi. 10,000 miles on them and they've got even wear. I know it's not apples to apples but the in truck MPG gauge says I get around 14-15mpg.
I did this for your scenario though.
Tire Pressure Calculator
Easy to use tire pressure calculator. Use our tire pressure calculator to calculate the new tire pressure needed when changing tire sizes.tiresize.com
I did it myself. Noticed improvements in shifts and more importantly accurate MPH/MPG readings.Thanks for the help. Did you get your speedo calibrated?
I used AlfaOBD yes. I forgot my exact tire diameter but I wound up chalk test/measuring them on a smooth concrete floor to help calibrate. Maybe they were around 2665mm circumference. HmmmDid you use AlphaOBD or something else? I'm weighing my options on paying the dealer or getting something to do it myself.
Nobody has been able to find the actual paint code. The official name is technical grayDoes anyone have the paint code for the BTS wheels? Tire shop scratched one and I need to get it repainted.
Sent from my Pixel 7 using Tapatalk
LSTNobody has been able to find the actual paint code. The official name is technical gray
Take it to a good paint shop, they can match the color with a sample.Does anyone have the paint code for the BTS wheels? Tire shop scratched one and I need to get it repainted.
No. They're all Crew Cab with the 5-7 bed, and they're all 4x4. Some come with a 3.6L V6 Pentastar, and some come with the 5.7L Hemi.Currently looking at a BTS, random question. Would anyone know if some BTS's happen to come with a 6'4 bed?
Some of the military editions were optioned with the longer bed, and some were quad cabs.Currently looking at a BTS, random question. Would anyone know if some BTS's happen to come with a 6'4 bed?
Do you know what year(s) those were? I've only finished compiling the 2022-2023 BTS data (trying to squeeze those scans in between my daily plant scans). Haven't started looking at earlier years. But for what data I have, it shows this (forgive the differences in formatting). I guess I assumed, incorrectly, that previous years were the same.Some of the military editions were optioned with the longer bed, and some were quad cabs.
The military editions ones were able to be custom ordered by the customer. So there was more variety in options and configurationsDo you know what year(s) those were? I've only finished compiling the 2022-2023 BTS data (trying to squeeze those scans in between my daily plant scans). Haven't started looking at earlier years. But for what data I have, it shows this (forgive the differences in formatting). I guess I assumed, incorrectly, that previous years were the same.
2022 data:
2023 data:
My truck is the unicorn here lol. BTS with a 6’4” box. Mine was a custom order 2021 ordered in December of ‘20dang. would have been nice.
Check this from the dealership on paint codes for 2022.Does anyone have the paint code for the BTS wheels? Tire shop scratched one and I need to get it repainted.
