ND RAM
- Nov 11, 2018
Okay folks, I present to you the first known OE-style dual exhaust swapped Tradesman. I did not use the factory cat-back but rather the Magnaflow system. This thread is a bit long but I tried to document the step-by-step process I used in case someone else wants to swap their Tradesman. With that being said I would highly recommend buying a truck with the factory duals if possible.
This is the factory setup that my Tradesman came with: side exit single exhaust with non-cutout bumper.
The dual cutout bumper sub-assembly comes from Mopar unpainted but in e-coat so you will have to have it paint matched to your truck. The reason this swap took so long for me was because I had the bumper ceramic coated, like the rest of my truck, prior to installing. There is a minimum 90 day off-gassing period for the new paint before the ceramic coating can be applied.
First, I removed the lower trim pieces from the bumper. I chose to do this first but if I were to do this project again I would recommend holding off until the bumper is removed from the truck. These are bolted on so they are relatively easy to remove with a 10mm and a flathead screwdriver.
There are five snap clips that hold the trim on in addition to the five bolts. These are easily removed with a little tension and a flathead screwdriver. The most difficult one to access is the tab on the outboard side from the leading-edge bumper trim piece. Retain the nut clips for reuse with the new cutout trim pieces.
The next step is to disconnect the bumper light wiring connector. It’s much easier to disconnect this now than to have the bumper supported only by wires later. The red piece (shown partially backed out) was somewhat bound from sand/grit on my truck. I had to work the locking slide (red piece) in and out to dislodge the grit until I could unlock the connector.
Next are the four outboard (two on each side) bumper bracket bolts. The nuts are 16mm.
After the outboard bumper bracket bolts are undone, there are two remaining bolts behind the license plate. Remove the license plate and carefully remove these two bolts. The bumper will be free so support it as your remove the bolts or it will pivot up into the quarter panel along the ends.
Once you have removed the bumper set it on a work bench or the tailgate using towels to prevent scratching of the original bumper. I found the tailgate is actually a really good height to work on it so I went with it.
