Hey I was wondering if anyone has had this issue. Went to go install rear wheelhouse liners and noticed on both sides it's not even painted. Didnt know if this was a common thing or not with the new Rams.
Thank you! I'll keep you updated on what I decide! Was just really shocked this being this way on a new truck!Hi @Jines2121 - If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please do not hesitate to follow up with us via private message. We would be more than happy to get you set up with a specialist for an additional layer of support for the dealer process.
Mark
RamCares
Thanks for help! Really appreciate it!I noticed that same greenish color while under the truck installing an exhaust. I’m going to say that it’s common.
Yep I guess your right. Definitely didnt think of that. Thanks for the help!Looks to be painted a base coat so technically it is painted. Base coat is cheaper than the color of your vehicle.
Thank youDefinately normal, as mine is the same.
