Can anyone tell me where I can get K07 relay?
Thank you,I did find one.Do you know the part number. What's it for. Looked on Mopar website and they list 2.
2001-2024 Mopar Mini Relay 68382350AA | Genuine Mopar Parts Canada
2001-2024 Mopar Mini Relay 68382350AAwww.genuinemoparpartscanada.com
2009-2024 Mopar Micro Power Iso Relay 68603769AA | Genuine Mopar Parts Canada
2009-2024 Mopar Micro Power Iso Relay 68603769AAwww.genuinemoparpartscanada.com
Great info.. My wiper washer is not working and I am not seeing a fuse for that on my 2019 Ram Rebel. Do not here the pump at all trying to work. Any idea if there is a fuse for the pump. ThanksI posted a diagram for the Internal Fuse Panel recently. This was good information to share with other 5th-Gen 1500 owners because the owner's manual doesn't contain such a diagram and the labels on the panel are very hard to read.
However, there was a lot more information that could be even more useful such as a diagram for the External (Engine Compartment) fuse panel as well as better detailed information about all of the fuses, relays, and circuit breakers. This took a while to compile but it was worth it because it will be a handy reference for anyone who could use it.
I created the information in a spreadsheet database and then published it on the internet. From here anyone can reference it any time online. I've also created two pdf document files if you wish to download the information directly to your computer or your smartphone. You can print a hard copy or keep it on your smartphone to access it easily if you ever encounter any issues on the road.
The website and the files both contain detailed information about both the Internal and External Power Distribution Centers, much more than the owner's manual or any other such documentation I could find. For example, you can now very easily find all fuse and relay locations and reference with expanded detail what each one does. Instead of using the esoteric acronyms used in the owner's manual to describe the fuses and relays, I've expanded most of them to their full names. This makes it much easier to understand what each one does.
Please see for yourself. Here is the RAM 1500 5th-Gen Power Distribution Centers website. Also, I've attached the pdf files for both the Internal and External Power Distribution Centers to this post. Simply download them to your computer and/or smartphone. From there you can print out a hard copy if you wish.
Here is a screenshot example of the partial Fuse Description table:
Here are the included Fuse Panel Diagrams:
External Fuse Panel:
Internal Fuse Panel:
The pdf files are attached below. One is for the Internal Fuse Panel, the other is for the External Panel.
I hope you find this information useful.
RAM doesn't list a specific fuse for the windshield washer pump. If you have a voltmeter, you can check for power at the connector.Great info.. My wiper washer is not working and I am not seeing a fuse for that on my 2019 Ram Rebel. Do not here the pump at all trying to work. Any idea if there is a fuse for the pump. Thanks
F35 maybe?Just to jump on the band wagon after an hour with power probe im throwing in the towel to ask for help. Anyone know the exact fuse that feeds the usb port in the lift up elbow rest for the center console. I checked every fuse i could under dash and in engine compartment and all look good. Trucks a 2020 ram 1500 limited ecodiesel new body.
Bump. Can a mod sticky this thread?
Thank You! THANK YOU! THANK YOU!! You are a Blessing to us all as we all go to this forum and look for Hal9001. Am installing Blackview today and needed this info... Also installing a DC-DC Charger and needed to find a D+. Thanks so much!!I posted a diagram for the Internal Fuse Panel recently. This was good information to share with other 5th-Gen 1500 owners because the owner's manual doesn't contain such a diagram and the labels on the panel are very hard to read.
You're welcome, glad I could be of some help.Thank You! THANK YOU! THANK YOU!! You are a Blessing to us all as we all go to this forum and look for Hal9001. Am installing Blackview today and needed this info... Also installing a DC-DC Charger and needed to find a D+. Thanks so much!!
I'll thank you as well, I haven't used the diagram yet but being a 12V enthusiast I can appreciate the time you put into this and I'll def be using it son enough!You're welcome, glad I could be of some help.
I’ll provide my thanks too for the write up and diagrams. Great info! Thanks!
You're very kind and I appreciate it, but there's really no need to thank me. Before I recently retired I was an electrical, electromechanical, and software engineer at IBM for four decades. I used to design and build industrial semiconductor test equipment. Part of the job was documenting what I designed, so this kind of stuff is right in my wheelhouse and no big deal for me.I'll thank you as well, I haven't used the diagram yet but being a 12V enthusiast I can appreciate the time you put into this and I'll def be using it son enough!![]()
Is this what you are looking for? Or the schematics.There have been a lot of people asking to make this a sticky so you can easily find it whenever you may need it. These requests have gone unanswered by the forum admins, so I just want to remind everyone that all the information here can always be found on this website that I created for it. The website will also work well on smartphones, so simply bookmark it. That way, if you're ever on the road and need it quickly, it will always be with you (provided you have internet access). There are also downloadable pdf versions that you can store on your computer and/or smartphone. You can also print the pdf versions (although the included links will obviously not be available).
Let me know if you would like any improvements or additions. I'm still trying to find the functions of circuit breakers CB1-CB4. If anyone knows their function or has access to the wiring schematics, please let me know.
Yes, exactly, thank you!Is this what you are looking for? Or the schematics.
This thread is stickied.There have been a lot of people asking to make this a sticky so you can easily find it whenever you may need it. These requests have gone unanswered by the forum admins, so I just want to remind everyone that all the information here can always be found on this website that I created for it. The website will also work well on smartphones, so simply bookmark it. That way, if you're ever on the road and need it quickly, it will always be with you (provided you have internet access). There are also downloadable pdf versions that you can store on your computer and/or smartphone. You can also print the pdf versions (although the included links will obviously not be available).
