Need Help - Trying to get Transfer Case into Neutral
BlueHemi1500
Richmond Va
Hello all,
I have a 2020 Laramie with the 5-position (per the manual) Transfer case.
I have read the manual and tried to follow the directions step by step, I just can not get the transfer case into neutral.
I downloaded the manual and printed out the relevant 2 pages for towing flat as my truck did not come with a manual followed line by line without success.
I held the button for several seconds and no response.
Do you push with the pen on what looks like an LED at the top of the switch?
I can get the transfer case to switch to each of the other modes, 2WD, Auto WD, 4WD high, and 4WD low without problems.
I have googled my question and tried YouTube for a solution.
I have also tried looking on the forums where I am a member, but no luck.
There are no error codes and no check engine light on the dash.
So please help me figure out my problem.
I am sure the vast amount of knowledge here will provide me with the solution.
Thanks in advance all.
BlueHemi1500
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Hello all,
BlueHemi1500
There is a letter N with an arrow above it, pointing up to the little switch. Put transmission in neutral IIRC and push and hold the little button, might have to have a foot on the brake also, should put the TC in neutral.
Should be somewhere in the 700 pages of the owners manual.
HemiDude
Ohio
Hello all,
BlueHemi1500
This is from my manual, I assume yours would be the same (step 4 is what you referenced):
Darksteel165
Massachusetts
Remove the plastic trim under your headlight switch and pull the rip cord to go into neutral.
Idk those weird witchcraft procedures people above are linking. It's an orange cloth cord.
dts828
Atlanta, GA
Whichcraft... Lol. I believe there talking about 4wd front transfer case not transmission.
Sent from my SM-S928U1 using Tapatalk
Kicker
Sounds like the secret sauce is first setting the parking brake...............
Nascar Tommy
My other Ram is a Dodge.
NW Indiana.
I mean it lost me when the manual said to use a ball point pen to...
That is quite complicated especially steps 6 & 7, but It's probably to ensure proper lubrication of stuff before a flat tow.
I don't think the dashboard trans disconnect is meant for long distance flat towing. It's an emergency thing.
DuaneMiller
Raleigh, NC
I regularly tow my truck behind a motorhome, and go through this process all the time... And once you do it a time or two, it becomes second nature...
1. Hook the truck to whatever is going to do the towing... Contrary to what the directions say in the manual, place the transfer case into neutral after you connect the truck to whatever is going to be tow vehicle. If you need to make positioning adjustments (pulling forward or moving backward), its easier to do it while the truck can move under its own power..
2. With the engine running, apply the parking brake, then the brake pedal, and shift the transmission to neutral.
3. Take a pointed object (ballpoint pen, etc. I use a small screwdriver) and depress the very small button just above the "up arrow and "N" and hold it there until the transfer case shifts into neutral.
4. A message will pop up in the center display: "4WD Neutral, Vehicle May Move Even in Park". There will also be a an amber "Neutral" indication that will light up just to the left of the odometer, and the led that you pressed will light up red.
5. I then shift into D or R just to make sure the transfer case is in neutral.
6. I disengage the parking brake
7. Turn off the truck so that Autopark engages
Video of Shifting Transfer Case to Neutral
Nascar Tommy
NW Indiana.
Just checked my manual, I have that same procedure listed on pg. 398.
While you're looking at your manual, is the truck on the cover the same color as your truck?
I've always wondered if they matched books to trucks.
My truck is Patriot blue so is my manual.
kapinallinen2
Southern Maryland.
No idea, never broke open the paper copy, still in its sealed plastic.
I downloaded the PDF file and use that.
edit: Just checked, my truck did not come with a paper manual, just with some useless "lets get started" booklet.
Darksteel165
Massachusetts
Did you buy it used? All new trucks come with the manual.
My manual has a black truck on it, my truck is black.
Darksteel165
Massachusetts
What trailer TPMS?
My truck was assembled April 2018, this was before tpms or paper manuals were invented LOL.
Trailer Tire Pressure Monitoring System. Sensors that come people that got some of the trailering packages. Sometimes the dealer would take it and hold it hostage or by mistake.
kapinallinen2
Southern Maryland.
I know what they are. The early trucks did not come with as many of the bells and whistles as the later ones did.
I faintly remember the conversations on how to download the owners manual on-line.
