Live where they're aren't any highwaysAnyone know how to disable the two large green icons on the top of the NAV screen that show up when on ahighway?
I agree that google maps or car play is better and would like to use them over the uconnect nav....just don't want to deal with the cable.This might sound like I’m being a smart you-know-what, but I mean it sincerely...
My solution is to not use the truck’s navigation, and instead use my phone with CarPlay (or Android Auto, if that’s the way you roll). My phone’s navigation is superior in these ways:
- It’s continuously updated
- Better voice assistance
- I can plug in directions before I get in the truck
- Better UI
- Easier to search and type
- Integrates with Yelp, my address book, etc.
On the other hand, the truck’s navigation is better in these ways:- Doesn’t require a cell signal
- Uses the full 12” screen rather than just the top half.
- Maybe shows up in the digital dash and HUD? I don’t have the HUD, and haven’t used it enough to say whether it shows up on the dash.
ya they are not there when when using a nav route.Live where they're aren't any highways
I seem to remember there being a difference between what shows up when your actually navigating vs not and I thought a lot of those icons went away when you were on a route....or maybe the opposite.
Buy the wireless CarPlay interface!I agree that google maps or car play is better and would like to use them over the uconnect nav....just don't want to deal with the cable.
Android for me.Buy the wireless CarPlay interface!
Thank you!You can disable this.
1. Go to “Nav Settings” on the lower right.
2. Select “Map Appearange”, and then choose “POI Categories”
3. Uncheck “Highway Exit”. That’s it.
Cheers,
View attachment 91226View attachment 91225
my screen was a little different than yours. Instead of checkmarks that are 'hollow' when unchecked and filled in with white when checked, my screen for POI categories just had the icon on the left of each item either gray (not enabled) or highlighted in blue if enabled. The screen one level up used checkmarks. I am thinking this is the right area it may be a glitch in the software that is not disabling that setting. I noticed you can uncheck all the POI categories...that did not work either.Dang. Thought for sure that would take care of it. If I figure it out I'll let you know.
To follow-up with the solution, it was indeed the Signposts settings in the route settings. No more green boxes. Even though its in the route settings menu it did disable the green boxes in both the in-route nav or not in an active route.I thought maybe it’s “Signposts” in the Nav settings? Mine is checked to be on, and I’m not seeing that, but not near a major highway either.
