SD Rebel
Is it just the Rebels having this issue? Anyone without the rebel package having this issue? Maybe it is something specific to the rebel package causing this issue. I've never noticed it on my truck, not sure if I would even notice if it was off .5", I will check it out.
It's not an issue, it's normal. Unless you have adjustable coil-overs your suspension will never be perfectly level. There is a weight difference from left to right on most vehicles, equal rated springs will mean the heavier side will sit lower. Factor in the driver's dynamic weight and over time/miles the difference actually increases as the springs slower wear in.
Get a tape measure. For the quick and dirty method, measure from the bottom center of fender flare to the center of the wheel. For the most accurate, measure from the level ground to the bottom of your frame. Either case, the driver's side will be lower.
