Like others have said, there's no need to use anything from the old pan other than the bolts.
Make sure you have a new gasket.
I saw online some use the collars. My instructions didn’t say anything in regards to those. I popped them out and test fit them. They looked like they would prevent the gasket from being fully compressed once installed so I didn’t use them.
They protruded from the PPE pan a bit. When installed in the stock pan they were much closer if not fully flush with the pan surfaces.
I suspect the gasket issue. You don't need to crank the bolts down with the factory style gasket. You can actually damage the gasket if you compress it too much.I suspect the only reason they are present in the stock pan is to prevent cracking/warping the flange since it’s plastic. Not really an issue with the PPE pan unless it prevents over compression of the gasket.
At some point I plan to re check my fluid and bolt torque. Been through plenty of heat cycles at this point.
I don’t know how many times I’ve reused a gasket thinking it’ll be fine….wrong! Don’t do it guys, unless you want to do it again.My PPE review:
The pan is a definite upgrade to the OEM. It holds more, it has cooling capability (aluminum with fins) and will make future filter swaps MUCH less expensive. A filter costs $30, a drain O-ring is $6, and a gasket (from KLM) is $27.50. Fluid cost would be the same (okay, add a quart for the bigger pan): Less than $65 instead of north of $250. I'll save $200 per filter change from here on.
The bad: no gasket??? WTF. And the "re-use the old one"? No...just, no.
Get the pan. Buy a gasket from KLM. Install a NEW O-ring on your drain plug. Add an aftermarket magnet to it if you want (like I did.)
Hopefully my experiences and suggestions will save you the time, trouble, and expense, that I had to go through to learn about PPE's shortcomings.
Again, the pan should help my transmission's longevity: cooler temps and more oil.
Good luck!
This isn't really a booklet. Folded piece of paper.Mine came with minimal instructions. Not a booklet like that, just one piece of paper.
That what I said in my post about my install as well.All Concerned,
I have the PPE deep pan on my 2022 RAM Ecodiesel. Was installed 2 months ago, never any issues/leaks with drain plug or leaks with the pan gasket.
My 2 cents...
The stock transmission pan flange collars (removable), provide three important functions; keeps the (stock "reusable" gasket) centered over the pan mounting holes, keeps the pan bolts centered in the mounting holes, and keeps the gasket from being over compressed when torquing to spec's.
Respectfully,
David![]()
The spacers also prevent over tightening the bolts and damaging the gasketHere’s some of my experience with installing my PPE pan .
I originally bought the smaller pan that takes one additional quart of fluid .
After the install I had issues with the truck going into park and not being able to get back into gear . I also had codes.
I thought that I had broken something and went ahead and had the truck towed to the dealer .
They discovered that the park mechanism was binding on the pan filter thus tripping codes and making the vehicle inoperable. They then installed the original stock pan and I was able to drive the truck until we came up with plan B .
I contacted PPE and they were skeptical that this could have happened.
I sent them the video the dealer had put together of the issue . That convinced them of the problem.
PPE offered me the larger pan ( 2 quarts additional fluid ) no additional charge and gave me 2 additional filters at no charge.
With that pan I ended up putting in a mix of 7 quarts of ZF and MoPar transmission fluid .
I did not use the spacers. My thought is that the spacers are there because of the plastic pan . Too much torque would crack the pan . With the aluminum pan not so much.
I did not level the transmission. I leveled the truck. At the dealer they just put the truck on a lift and have the truck level .
So far alls good. It has been most interesting to read of everyone’s experience and to hear the different opinions and options that have been put forth.
I also installed the additional 1 quart pan. My truck is levelled, and I used 4 jack stands to get the wheels off the ground. I had no issues when I started the filling procedures, then a minute or so after I had completed them, it would not shift into park, gave the error message in the cluster - no issues with any other gears. I also thought I had broken something and checked for codes etc. but literally had none.Here’s some of my experience with installing my PPE pan .
