My hoses aren't labeled in and out specifically. I have a thick hose on the bottom. And a thin hose right above it. And I did pull back the web sheathing over it. But I'm not sure which one... I assume it's the thinner one but I'm not 100% sure.Take a look at the water pump. There are two rubber heater hoses. They are labeled IN and OUT, you may have to pull back the sheathing a little to see the writing. You want the ball valve on the OUT side of the water pump
I made this simple modification on my 2009 "classic" shortly after getting it - several years ago. I bought it in December of 2019 so it must have been in the spring of 2020. I cannot follow your pictures but coming off of the water pump there is a big flexible hose and a smaller one. The smaller is on top. If you follow that, there is a metal pipe in it with a T. On the top of that metal line, the T fitting (steel) come out headed up and goes to the heater core. I cut the hose connected to that T and put the valve in it. Works fine. AC is better, with the valve open the heater works normally. The other part of the metal line goes to something else but the hose I cut only goes to the heater core.
My "classic" is not totally the same as a "normal" Ram 1500. It does not have the mild hybrid system. I don't know if the differences include something related to the heater core piping but this mod works on my 3.6 V6.
Be prepared for that valve to stop working over time. I have one like that in my 2000 Dakota and after a few months of engine heat it started getting hard to turn. Now it won't turn without the use of pliers and even then won't fully close anymore.Sorry, I don't check this forum every day and just noticed this request. The image labeled "Truck 1" is from the front of the engine. At the bottom, in the center, you can see the small and large hose coming off the water pump. You want to follow the small one and, as you can see, it transitions into a metal pipe. The image labeled "Truck 2" shows that same pipe where it passes the dipstick. About in the center of the picture you can see clamps I added when I cut the line going to my heater core. You can kind of see the metal T fitting that the hose I cut comes off of. Truck 2 is still from the front of the engine, just a smaller area. Truck 3 is down on the passengers side of the engine looking at the same hose and again you can see the worm clamps I added. The valve is between the clamps. It's small and hard to see. I hope this helps, I do not know if my plumbing is the same as yours.
When I had this valve, it started leaking in a week. The ball valve from Lowes is much betterBe prepared for that valve to stop working over time. I have one like that in my 2000 Dakota and after a few months of engine heat it started getting hard to turn. Now it won't turn without the use of pliers and even then won't fully close anymore.
Do you have any pictures I still don't know where to put the valve on a 2019 ram 1500 v6 hybridIt has been said in the other thread to not cut the hose. Disconnect the hose, add valve and then add a short new piece to the other end of the valve. That way if you need to go to the dealer you remove the valve and short piece of hose. It will still look factory then.
It’s been discussed somewhere. I’ll let you know if I can find itDo you have any pictures I still don't know where to put the valve on a 2019 ram 1500 v6 hybrid
