CobraKai
I had the same issue when my 2025 limited was delivered from Mark Dodge. Tailgate worked fine as normal but split would not work, no sounds nothing. I started to panic regretting getting rid of my 24. then I slammed it shut in frustration and BAM. everything works fine and has worked for months no issue now... go figure lolNothing wrong with my 60-40 doors. The issue was the regular tailgate was not closed hard enough and therefore the release button would not work on the larger of the barndoors. You can't close tailgate normally, you must slam it shut. Even if latches properly, for some reason it doesn't register for the barndoors to open unless you slam (or close very firmly).
