Mopar total clean
Volts44
What is everyone using to clean leather steering wheel and other leather
A little bit of soap and water. Mothers VLR is pretty good also, and so is Chemical Guys interior cleaner.
Chemical guys quick interior cleaner is what I’ve been using.
use anything from brands your recognize. Look for anything that says cleans and protects and avoid conditioner. You want a clean finish when you are done not glossy. I use gyeon and colorguard.
Ive been using this total clean.. seems to do a good job.. use it on everything in the interior.
Use Artdeshine Citrus Cleaner (Because it is Ph Neutral and won't harm leather or plastic) and then coat/protect with Leather & Plastic Coating is awesome! Very clean finish and does not make glossy or hard. Do not use a High Ph Cleaner. Anything over Ph of 7 then be careful.
Follow the instructions in the owner's manual. You do not want to use cleaners that will remove the natural oils from the leather.
Is it even leather??..
Gyeon is for real.
I like Lexol...it has been around forever and one of the best cleaners and conditioners on the market.
I use P&S Xpress diluted 1:1, or straight from the bottle if cleaning something especially dirty.
I use a damp microfiber once in a while. 4 years, 50k miles, still looks like new.
i just use baby wipes with no added fragrances. MF with water works too. Definitely not use hand sanitizer wipes or anything that has strong chemicals.
The problem with sanitizer wipes is the alcohol. It dries the leather out
I use Meguiar's Gold Class Rich Leather Cleaner & Conditioner and apply it on a microfiber cloth so I can get the correct amount anywhere I need.
Looks great and dries perfect.
alcohol. that's the word i was looking for lol
this is what happens when you only speed for 3 hours in 48 hours :sleep:
