Mopar total clean
Volts44
What is everyone using to clean leather steering wheel and other leather
djevox
VP of Creative Thinking
MD
A little bit of soap and water. Mothers VLR is pretty good also, and so is Chemical Guys interior cleaner.
PurpleRT
Chemical guys quick interior cleaner is what I’ve been using.
Cajun_
Louisiana
use anything from brands your recognize. Look for anything that says cleans and protects and avoid conditioner. You want a clean finish when you are done not glossy. I use gyeon and colorguard.
NewLove
Ive been using this total clean.. seems to do a good job.. use it on everything in the interior.
MBORO19RAM
Use Artdeshine Citrus Cleaner (Because it is Ph Neutral and won't harm leather or plastic) and then coat/protect with Leather & Plastic Coating is awesome! Very clean finish and does not make glossy or hard. Do not use a High Ph Cleaner. Anything over Ph of 7 then be careful.
NewLove
Follow the instructions in the owner's manual. You do not want to use cleaners that will remove the natural oils from the leather.
Is it even leather??..
securityguy
North Florida
SnowBlaZR2
Fuel Economy Champion
FL
I use P&S Xpress diluted 1:1, or straight from the bottle if cleaning something especially dirty.
boogielander
i just use baby wipes with no added fragrances. MF with water works too. Definitely not use hand sanitizer wipes or anything that has strong chemicals.
Darksteel165
Massachusetts
The problem with sanitizer wipes is the alcohol. It dries the leather out
I use Meguiar's Gold Class Rich Leather Cleaner & Conditioner and apply it on a microfiber cloth so I can get the correct amount anywhere I need.
Looks great and dries perfect.
boogielander
alcohol. that's the word i was looking for lol
this is what happens when you only speed for 3 hours in 48 hours :sleep:
