vincentw56
- Aug 5, 2020
Yes.Hi Jay, you were mentioning using AlfaOBD to turn on the feature for factory Bed Lights. "Additionally, you need to set CBC I/O A5 enabled to yes and CBC I/O G16 enabled to yes in the BCM configuration and the cargo bed lights will be as OEM intended in regards to wiring and function." Is the CBC I/O A5 is that the 2014 CBC Config I/O -Bed Lighting Present - Pin A5 section. This is the only one I can find listed for the pin A5. Thanks
Sent from my SM-S908U using Tapatalk
