MaxTrac rear leveling kit
JMIngrodi
Does anyone knoe if the MaxTrac 2" rear lowering level kit drops a true 2" ?
I just measured my front and rear and Im only off by about an inch and a half, maybe 5/8.
Im gonna be real mad if I end up lower in the back. I hate that look!
I read where some guys had to cut the coils to get true level. But is that consistent? What was the starting measurement?
Thanks for any help!
djevox
VP of Creative Thinking
MD
It’s not lower in the back. I had them on for a month or so before I went the opposite direction and installed a lift kit. I didn’t cut any coils either.
ferraiolo1
North Central PA
Mine is about .25in higher in the back. Which is ok so it’s not really squatting when I put anything in the bed
djevox
MD
Here’s what mine looked like with the reverse level
JMIngrodi
I would be ok with .25 or less. I just dont want to be lower in the back than the front.
JMIngrodi
Im not sure what you mean. What isnt lower in the back ?
djevox
MD
Whats a "reverse level"
Reverse level is leaving the front stock and lowering the back 2 inches to get rid of the rake
I’m referring to the 2 inch rear drop springs that you mentioned in your original post that you were worried would be lower in the rear.
have you done any research yet?
JMIngrodi
Ive only dug around here on the forum a little. Unless Im missing something, if the springs lower the rear by 2" , Im going to be sitting a half in too low in the back. So I was checking to see what everyone elses experience was.
ferraiolo1
North Central PA
I’ve not seen any truck in here that was lower in the back with the maxtrac progressive lowering rear springs
2020SilverMidnight
I've had them on my truck since 1700 miles, I'm at over 27K now with no issues and it's not 100% completely a 2" drop. Mine still has about 1/2" rake. Meaning the drop was only about 1.5" for me.
ferraiolo1
North Central PA
If you look at my topics. I have a build thread with all the info and clearance pictures.
JMIngrodi
I appreciate you guys help so far. Im sorry I didnt know it was called a "reverse level" but this IS what I want to do to my 19 bighorn.
ferraiolo1
North Central PA
Scram1500
I had the Maxtrac springs for a while and can confirm that there is still 0.5" of rake and ride feels the same. You won't end up in Carolina squat
JMIngrodi
Finished this up today and it turned out great. Theres about a 3/8" difference gap in the rear wheel well than the front (measuring from the top of the tire to the edge if the fender.) Im happy. I read they could possibly settle some too. Thank you your help!
Whoa_Ram
Azle TX
Mine was a little higher in the rear as well. I'll see if I can find a picture.
