ike4president1970
Just lowered my 2022 Ram 1500 Bighorn Night Edition with the Maxtrac 2/4 drop kit. Did not use the track bar relocation bracket. Opted for the Spohn adjustable panhard bar instead. I had read that many people were not happy with the rear axle alignment with the relocation bracket, as it was still not centered. The drop looks perfect. The rear is maybe 1/4" higher than the front, so not even noticeable. I have Fuel Rebel 22x10, -13 offset Satin Black wheels with 305/45 Toyo Proxes ST III's. Rides very smoothly. A touch stiffer than stock, which is to be expected. Ground off rear bumpstop brackets and installed Belltech progressive 2" bumpstops directly to the frame. The OE brackets were only about an inch from the axle, so were bottoming out on metal every bump. When you grind off the OE bumpstop brackets, there is already a hole for the new threaded bumpstop to go through, so it's quite easy to install. Make sure and shoot the ground metal tack welds with a little black rustoleum paint to eliminate rusting Inside I have a Phoenix Audio 13.6" PX6 head unit, 2 10" Sundown Audio SA10 D4's, wired parallel in a ported down fire enclosure hooked up a kicker 2400 w max (1200 rms) monoblock amp, and 2-farad capacitor. Replaced four doors with JBL Stage III 6x9 two ways. Infinity Kappa 3.5's in the dash, and Infinity Kappa 2.5" in upper back doors, powered by a kicker 1200w 300x4 amp. AfE Dry Filter Cold air kit under the hood. Carvin Matte Black 5" exaust tips. Pedal Commander, set to Sport 3, tucked behind the center console. On order are smoked taillights and third brake light.
