GM convert
- Apr 8, 2018
Anyone else go fast? Mine shuts down at 105. Are there any tuners that can change this? Thanks.
I believe the recently released Diablosport tuners have the ability to change the speed limiter BUT you need to swap the whole PCM to an unlocked one. $$$$Anyone else go fast? Mine shuts down at 105. Are there any tuners that can change this? Thanks.
The new '19's are locked and can't just plug in a tuner like the older models. Not saying it won't be done in the future but currently you have to send your PCM/ECU in for reprogramming.I had a Superchips for my 03, and never needed a new PCM... it stored the factory values and made the changes... and it also uped the speedo governor from 112 to 145-150. I got it to spin the rollers on the dyno at 145. I have not started checking for my 19....
I believe our trucks are governed to the max speed of our tires, makes sense.
Takes all the fun away, like the first hemis having 2 pcms, so no aftermarket touched themThe new '19's are locked and can't just plug in a tuner like the older models. Not saying it won't be done in the future but currently you have to send your PCM/ECU in for reprogramming.
2016+ are locked and require replacing. None of my other vehicles were like that so it did come as a shock to me.
[/QUOTE
that is crap.. hate to spend the extra for that.. was a nice addition to the MSD HEMI 6 coil packs I had on it.
Mine caps at 104MPH, but my stock OEM tires are rated at 130MPH so I am guessing it is just what some engineer thought was acceptable.
I just went to the Superchips website, and see a tuner for the 2019 that would do limited things, but one was to Speed/Rev Limiter options... without a PCM, this is close to what I had for my 2003 Ram 5.7
From Superchips website. This is for the Flashcal options, (not the paq) price is 249.95, the flashpaq is 499.95 (includes PCM swap), DashPaq is $719.95 (includes PCM swap)
If you are a 2019 Ram 5.7L New Body truck owner who is looking for a device to help calibrate for your large aftermarket tires, read/clear trouble codes, adjust your speed limiter and more, then look no further. The Flashcal for Truck is a product designed to give features and calibration tools to truck owners at a great price. The days of clunky, outdated calibration tools are over. Flashcal has trucks covered and the market cornered with quality and pricing that can't be matched.
Corrects speedometer for tire upgrades between 25- 40*
Speedometer recalibration for gear /axle swaps *
Speed/Rev Limiter Options *
Idle Up *
TPMS Options *
Reads and clears diagnostic trouble codes
Digital Battery Voltage Display
Real time Data Logging
Real Time Data Monitoring
Upgradeable to Flashpaq Tuning **
