Lowered the rear 2" last night.
Question about your tow mirrors, did u order them or did they come with the tow package? I got the tow package but also got blind spot option, i was hopimg not to get those big mirrors
Well decided to lift it, so I removed the springs and bags. Going to order either Fox or King coilovers in a few weeks.
If anybody is interested in the springs & bags let me know! only had 1300 miles on them. Located in DFW.
Interested. How much? Also, shipping to 19083. Thanks.
What is a safe amount to cut off of the maxtrac coils? I've already cut off a little more than 1 full coil on the passenger side and just about 1 on the drivers side.
My current measurements are:
DF: 35 5/8
PF: 36
DR: 36 1/4
PR: 36 3/8
Am I being a spaz about wanting the rear to be 36 even? Is it safe to cut the coils more than what I have already?
Thanks for any advice.
DF: 35 5/8
PF: 36
DR: 36 1/4
PR: 36 3/8
I wouldn’t cut anymore. You will then risk the chance of the spring falling out when the truck is raised on a lift.
Finally did it! Thanks to all the information everyone else posted I am not mechanically inclined but managed to figure it out once I had the correct sockets. I went with the jack from the pumpkin, install jack stands, remove tires and lower rear axel using jack, method. Probably took 1.5 hours really taking my time. haven't taken any measurements or a drive yet but I'm still seeing a lot of rake so I may need additional adjustments.
These are the coils, https://www.suspensionsuperstore.co...2wd-4wd-premium-2-rear-lowering-coils-272920/
This video was helpful,
I had to cut the 272920 coils to get it almost level. Ended up getting the 272720 coils also, and they sit damn near level without cutting anything. Still might cut a tiny bit. Rear is off by P - 5/8 and D - 1/4. The DF is at 35 5/8 and PF is at 36 1/8. What are your measurements?
The guys that have done the rear springs, anyone have the eTorque motor? The reason I ask is that some of the places that I've looked at springs states that the eTorque trucks sit lower in the rear with the spring.
When I had it too, the rear wasn't lower. It was about half an inch to three quarters of an inch higher in the rear.
Has anyone here used the 272720 springs on the etorque 4wd truck? Wondering if that will give me negative rake and if I should go with the 272920 springs and cut as needed to get a level drop? Truck is a 2022 etorque ram sport gt
Thanks
Thanks
I have a pair of the 272920a from Suspension Store that I tried on my 24 Laramie G/T eTorque and it ended up as negative rack, so I took them out...most DTs have about 1.75" rake.
