Low Hum slowing down
gibbynd
I've noticed the last few days that when the truck is slowing down or I'm applying the break at low speeds to slow down I'm hearing a low humming noise coming from the front front/left end. I just had the oil change and tires rotated and they didn't see anything out of the ordinary. Any thoughts?
Sorry to hear of the trouble you are experiencing, @gibbynd. If you are unable to remedy this concern with the assistance of fellow forum members, I kindly suggest connecting with your local Ram dealer for further support. If you are in need of any assistance with that process, please feel free to send us a private message.
Mark
RamCares
When looking for my truck I test drove a 2019 Rebel that had 20k miles on it and it had that same issue and it was pretty bad. The dealer tried to convince me it was the tires (which did contribute slightly) but it sounded to be like either a wheel balance issue or a worn/warped rotor. I now have 18k miles on my Rebel and I do notice a similar noise - though not nearly as bad. It seems to me that this may be a wear issue with a consumable wheel/tire/braking component. At my next service I will have them perform a high speed balance. On previous cars this has solved similar issues. Best of luck
Hi @NYNJ8 - If you are in need of any additional assistance when addressing this with your dealer, please do not hesitate to follow up with us via private message!
Mark
RamCares
Let me know if that does the trick or if they find anything.
