Lost texting going from Iphone to Android
yellowboy
North Carolina
I just switched fron an Iphone to an Android (Galaxy s10e) and can no longer respond to texts on the truck screen. It only allows me to use one of the pre set answers. Any way to change this ??
Kidder
DFW, TX
You must have been using Apple Car Play before. You need to use Android Auto now. Uconnect only has the canned responses.
piening2150
Other way around. He has Android now. Plug it in and use Android Auto. Google will send any message you dictate.
piening2150
Also, with an iPhone, CarPlay is automatic (I believe) when you plug it in. With Android you will have to download the Android Auto app to your new phone first, then plug it in and go thru a couple steps to set it up on your phone before it's ready to go. After that it's automatic whenever you plug it into your truck.
GRAYWOLF
DFW
Mine only works when plugged in.
yellowboy
North Carolina
OK so I need an app to do this ? It does not send a return text message now either plugged in or not plugged in. My iphone did it either way, I just talked, she repeated it and said "do you want to send this ?"
piening2150
Yes. See my post #5 above.
67GeeTeeX
Buckeye, Arizona
I had to download google message app to get mine to work properly. The Samsung message app, on my phone was not compatible
yellowboy
North Carolina
I did a google app but still no go plugged in or not. I get " say a pre defined message or say list to see the list ........ Called Ram Care they are clueless.
piening2150
Are you pressing the VR button on the steering wheel to send a message? If so, you can't just tap the button, you have to hold it for a sec.
Just tapping it uses the truck's Uconnect system to reply (limited canned choices).
Holding it for a sec gets Google on the line (when plugged in) and you'll see this instead-
Then you can ask it to "Text Grandma Mobile" or whatever and it'll say "Sure. What's the message?".
Also, you need the Android Auto app installed on your phone. Without that, it won't work.
RamCares
Michigan
We're sorry to hear that you are experiencing this concern. If you would like any additional assistance, our team is always available via private message!
Alison
RamCares
Kidder
DFW, TX
Thanks piening - still no go even with the same displays I'll play with it some more today
Make sure you're using the factory cord and not an aftermarket. For my Samsung Note 8, it only likes factory Samsung cords.
yellowboy
North Carolina
Thanks on the cord ---I HAVE been using an aftermarket --and Ramcares thanks I will contact you if I can't figure it out.
magic280z
I've only gotten android to work with android auto cable connected. One of my biggest complaints about Android is it's over reliance on Android auto and not basic Bluetooth hands free integration. Uconnect also messes with this in not supporting Android as well as iPhone or paying for Uconnect. Cell phones do the same thing oems need to quit paying developers for custom instantly out of date solutions and just do better cell phone integration.
2019 Ram 1500 Laramie 4x4 - Crew Cab/5.7 Bed - 5.7 Hemi - 3.92 - Anti Spin - Level 1 Options - RamBox - BUG
_StangPGH
The new version of Uconnect will support wireless Android auto but sadly it won't be compatible with the current hardware. There's a thread somewhere here on it.
GRAYWOLF
DFW
Does your phone have Android Auto? If not, you have to download it. My S9+ came with it.
