chucka
- Sep 28, 2018
I wish I would have taken more and better pics, but it's pretty simple to do.
I'm posting a pic of the Lock'er Down instrucstions below.
The only issue I ran into is how to take the little plastic tabs out in step 3 and 4..... The clips broke, but the only thing I can see them there for is to hold the divider up, and with the safe installed you really don't need them.
The safe is held in by 4 self tapping screws. Two of them go through Holes on the back of the safe, and the other two are at the bottom. You can see the holes in the pictures I'm posting.
When I cut the rubber mat on the bottom I just used an razor blade. You can see where I cut them and I think it worked out perfect. If I ever decide to take the safe out I believe I could put the rear piece back in and it not really be noticeable.
I've only had it installed a couple days, but here is my 2 day review. Quality is top notch, customer service is beyond excellent.
The only negatives I have are
a) the bottom is open to plastic. my GMC model was full metal everywhere.
b) how it's mounted, by self tapping screws. again, My GMC had 2 bolts that held it in place in OEM holes. but I can see why they did it this was as there is no mounting holes where the safe is.
I highly recommend this to anyone.
Also, this will not fit the Limited or Long Horn as of now (11/29/18) - Let me explain this, it will "Fit", you just won't be able to slide your console back. But come to find out the Mopar one has the same issue.
I posted these pics in the "awesome console safe" post, but thought it may deserve it's own post.
