Location of fuse for ram box 115v power outlet
A36B7619-40ED-4941-90C8-3FB583E2C333.jpegWhich fuse (s) is my ram box 115v plug on for my 2019 Ram Limited? The plug no longer works and the button for the power switch by my left knee no longer illuminates when I push the button to activate the ram box 115v power outlet I’m assuming it’s a fuse but cannot find it’s number/location.
Just out of curiosity, are your rambox lights working? Had the same issue, thought it was a fuse but it turned out to be a harness inside the center console being cut from the hinges every time I opened it. It caused my interior ambient lighting and rambox lights to fail.
Yeah, Ram box lights work. Actually all my 115v outlets inside the cab of the truck work too. It’s just the Ram box outlet that’s not working.
Well…still no luck with finding the fuse/relay for the 115v outlet in my ram box for my 2019 1500 Limited. Anyone have any more ideas on which fuses/relays to check?
stupid question but did you turn it on by the inside cab switch? the outlet does not.work if you dont put this switch on, near the light dimmer near your left knee when in the driver sear
this switch , if my knee wasnt broken i would take a actual pic in the truck for lacoation
heres a pic from youtube sorry its blur a bit, its under the pedal adjustment switch on th right of emergency brakes
Yeah, the switch on the dashboard by my left does not illuminate anymore when I push it which leads me to believe it’s a fuse…just don’t which fuse and/or relay it’s tied to
Yeah, I don’t know if the switch has gone bad…seems unlikely. The switch no longer illuminates when I push it…leads me to believe it’s a fuse or relay
Yeah, the switch by my left knee no longer illuminates when I push it. Leads me to believe it’s a fuse.
If all the inverter outlets are dead, then check F60, 50A fuse in the IPDC.
If only the RAM Box outlet is not working, the system could be sensing a fault to ground, thus disabling the exterior outlet.
I have the same problem f60 fuse good but no power
