Superdavegator
- Jun 5, 2019
| F12 | Micro2 | 25 | Clear | Audio Amplifier Module / Active Noise Cancellation (ANC) / Sine Wave (SW) Inverter |
Thanks…I’ll give F12 a try tomorrow. And that is a cool page that was created!Try
F12 Micro2 25 Clear Audio Amplifier Module / Active Noise Cancellation (ANC) / Sine Wave (SW) Inverter
And thank @HAL9001 for creating this page
Yeah, Ram box lights work. Actually all my 115v outlets inside the cab of the truck work too. It’s just the Ram box outlet that’s not working.Just out of curiosity, are your rambox lights working? Had the same issue, thought it was a fuse but it turned out to be a harness inside the center console being cut from the hinges every time I opened it. It caused my interior ambient lighting and rambox lights to fail.
stupid question but did you turn it on by the inside cab switch? the outlet does not.work if you dont put this switch on, near the light dimmer near your left knee when in the driver searYeah, Ram box lights work. Actually all my 115v outlets inside the cab of the truck work too. It’s just the Ram box outlet that’s not working.
oh my bad, thanks@crusher ...Take a second look. He mentioned the switch in his first post.
Yeah, the switch on the dashboard by my left does not illuminate anymore when I push it which leads me to believe it’s a fuse…just don’t which fuse and/or relay it’s tied tostupid question but did you turn it on by the inside cab switch? the outlet does not.work if you dont put this switch on, near the light dimmer near your left knee when in the driver sear
Yeah, I don’t know if the switch has gone bad…seems unlikely. The switch no longer illuminates when I push it…leads me to believe it’s a fuse or relayheres a pic from youtube sorry its blur a bit, its under the pedal adjustment switch on th right of emergency brakes
Yeah, the switch by my left knee no longer illuminates when I push it. Leads me to believe it’s a fuse.stupid question but did you turn it on by the inside cab switch? the outlet does not.work if you dont put this switch on, near the light dimmer near your left knee when in the driver sear
yeah theres a good chance, have you look into that (fuse)Yeah, the switch by my left knee no longer illuminates when I push it. Leads me to believe it’s a fuse.
I have the same problem f60 fuse good but no powerWell…still no luck with finding the fuse/relay for the 115v outlet in my ram box for my 2019 1500 Limited. Anyone have any more ideas on which fuses/relays to check?
