Limited towing capacity
Bas
CO
Thinking about getting one, 4x4, most options except panoramic roof and 22 inch wheels. It has the 3.92 axle. Loading it with 650 pounds of dogs and humans. Looking at getting a trailer 4250 dry, 7100 wet and probably putting most of the gear in the trailer. Doable?
devildodge
Moderator
Central Pennsylvania
We have a few payload stickers from Limiteds. I would say it would be doable. Just be sure you pay close attention to the real world numbers. You may have to keep the trailer close to empty for tongue weight though.
Zeronet
Florida and West Virginia
If you are looking at a particular truck, look inside the driver door at the yellow sticker to get the payload for THAT truck (or call the dealer and have them send you a pic of it). Then do some math.
650 for passengers + 85 for a good weight distribution hitch. So 735. Subtract 735 from the number on the truck payload sticker and you get your maximum trailer tongue weight when loaded with all your gear. Figure 10% of the maximum trailer weight (GVWR number on the sticker on the side of the trailer). So for a 7100 GVWR trailer that’s 710lbs.
710+735= 1445
So in this example , if the payload sticker is at least 1445 you should be safe and legal to tow it.
YoAdrian
Moderator
RI, USA.
710+735= 1445
Hey @Bas listen to Zeronet he’s the shiznit very well informed sir on payload weights. Choose your trim level and options wisely since a loaded up Laramie can be in the 1300s, Limiteds even lower so like 1100ish! Go check out which options are heaviest in Zeronets posts in the towing section and see if you can do without the heavy stuff (big gas tank, ramboxes, sunroof... like all the stuff I ordered...)..
Deshatt
My Limited matches what you describe (3.92, no sunroof, no 22s) and my payload sticker shows 1556.
