  • We have been battling an on and off issue with registration verification emails not being sent out with certain users. We have finally got the issue resolved so if you have tried registering for the site but have not received a verification email, just request another verification email when you log in and you should now receive it. If you still don't receive the verification email, send us an email at [email protected] and we will get it resolved for you. Thanks!
level kits, worth it?
wino714
Hello all,
New to this site and I'm sure this has probably been asked before but i would like some fresh input. I am looking to do a 3" level in the front and 2" in the rear. I've heard that to high of a level can cause damage the suspension parts? does that sound correct? any input would be much appreciated.
db252
BayArea CA
Sounds like your planning a ‘lift’ more than a ’level‘ albeit a minor lift compared to most. A level is more just bringing the front up to the rear height in stock format. Most complete lift kits are designed to level the truck. Now a complete kit will contain components (UCA’s, end links, etc) to allow all components to work together properly together. If you plan to just raise the truck with components that are only designed to lift it and keep stock connecting parts, you’ll be changing and possibly exceeding the design of how they are supposed to operate.
I‘m doing a level on my truck which is only affecting the front and going up around 2” and I’m still changing my UCA’s to the Mopar 2” lift design to prevent any issues with the ball joint especially since I have air suspension. Plenty have gotten away without changing them and some have had issue.
To sum it up, do it right the first time based on your goals and you and your truck will be happier.
