Let's talk about 18" Wheel Fitments
Gregg
Thanks for the feedback. Yeah our designers have all the caliper specs available. We usually reference the front of a GMC AT4 and the rear of the RAMS as those are the most challenging.
I chose my tire-wheel package for a weight compromise to the stock wheels/highway tires. 18x8.5 ET0 offset and an LT275/70R18, coming from the 20x9.0 stock wheels with the non-LT Bridgestones. It's flush to the fender flares (Sport Edition).
djevox
VP of Creative Thinking
MD
At present we're leaning towards 18x8.5 on +0 and +18 or +25. We're just carefully researching the +18 and +25 for now.
I didn’t realize you were going so narrow. An 8.5” width and 0 offset would have the rim tucked and tire probably flush. I want to change my setup to ~35” tires, and am trying to decide right now between 18’s or 20’s (both in 9-10 width). I’m thinking I’d want the rim close to even with the fender so there’s only tire poke.
Do you do any kind of custom colors?
BRINK WHEELS
Precision Engineered Flow Formed Wheels
Miami, Florida
We don't have 18"s as of yet however we do have 20x9 +18 which will offer you the stance you're looking to achieve. I'm afraid we don't do custom colors.
SoCalSteve
I’ve got 295 wide tires on +1 offset wheels, and the look with OEM fender flares is perfect for me. I’d never want a lower (more negative) offset, though of course others go for a different look.
But, in a magic world where I could get anything I wished for, I’d pick +6 or +12, simply because this should mean less dirt and gravel kicked up onto the side of my Ram. More aggressive looking than stock, but easier on the paint than my current set.
can you share a picture
jimothy
5thGenRams Supporter
Atlanta, GA metro
Here’s a couple of driveway pictures I took just now. The last one shows the brake caliper clearance. It’s close, but the picture makes it look tighter than it is. Probably a bit over 1/4 inch clearance.
Playmaker10
SoCal
I feel a lot of people with 18-in rims are going zero offset or -12.
The thought of -12, is mostly with a lift, which will come with bigger tires, 35s or bigger. The negative offset will allow clearance inside the fender well for the UCAs and fenders.
SoCalSteve
jimothy
Atlanta, GA metro
Thanks Jimothy! Were you able to fit a 295x70x18 spare in the spare tire location under the bed?
Yes, but only by removing about a 1/4" from the inside of the hitch receiver, being careful not to cut into the weld. I did not remove the heat shield, but that's another option.
