Thanks for the compliments , Love playing with these things. The installaion involved removing the bottom grill section. I plulled out on the chrome which popped right out from left to right . At that point I had access to the core which is black plastic I then used a An osscillating saw with a fine wood blade to cut the small attach points and removed the section. Of course I first measured to ensure that the light would fit Height, and depth. it is as close to a perfect fit as one could get.
Next the mounting was made to the hard plastic base on the active grill shutter system, no modifcation was made to that unit, that is why I choose the bottom section, I would have used the top to keep a horizontal line of LED light across the front but it would have interfered with the function of the shutters IMO. I mounted using #14x 1.25 self tappers seems to be very secure. after that I just ran the wires as needed and done. Total time was about two hours.
2019 Rebel The light spread is much better on the open road, I think my row of coco plums obscures the beam.
As the pictures show, the curve of the light bar is a perfect match to the curve of the grill an unexpected but very welcome plus.
