Good morning RAM FAM,
I recently upgraded my lights to LED (truck did not come with this package) Well when i woke up yesterday i noticed the LED strips on the driver side stay ON even though the truck is completely off and locked.
I have tried the following with no luck:
1. Disconnect the battery (both positive and negative)
2. Rewire the LED Harness (it comes when you buy the headlights)
3. Change setting on UCONNECT under "lights" turned everything off , back on, etc.
Solution so far while this is fixed:
Unplug the main harness that goes to the headlight( luckily i have access to it without removing the whole front end again) or else my battery would probably drain.
Link to where i bought them:
www.infotainment.com
2019-2022 Ram 1500 DT Truck OEM Factory LED Headlight Upgrade Kit
INTRODUCTION Another highly anticipated Infotainment.com upgrade! Upgrade today to the factory Brand New Ram OEM LED headlight set (including right & left) 100% fully plug & play for the new 2019+ Ram 1500 DT (New Body). Simply remove your factory base-level quad headlights and replace with our...
