LED Cargo Light Options
Just installed the Diode Dynamics bulbs this weekend. They're seriously bright! I really like them. No key fob issues per say but I am having an intermittent issue where I can't lock the truck with the button on the door handle, which probably relates back to the key fob somehow. Only happened a couple times so we'll see if it keeps happening. Otherwise, great quality bulbs!
I went straight for the best ones. Diode Dynamics.
Spend the $100 and get the trio (2 cargo, 1 brake light) and just be done with it.
They also don't affect the key FOB transmitter the way some other LED replacements do.
Do you have to buy the resistor kit?
No they are plug and play. I have the same bulbs and they replace exactly like the bulbs you remove.
Purchase a tube of silicone. Then on that rear light gasket just put a dab on the rubber both sides to make sure it don't leak afterwards.
