- Nov 20, 2020
- Location
- Free State of Florida
I just went out and tried remote start and it did not do the test. Must have to push the start button.
You can remove them from the truck, sell them and buy a set of fixed boards.Wish you could get a Limited without the Power Running Boards.
Yeah, I'll trade you.You can remove them from the truck, sell them and buy a set of fixed boards.
I wish you could get a Limited night edition with Ramboxes without the soft cover, that gives you the bad "black rails" that cost you $350+ to replace to be able to use any other cover :-/Wish you could get a Limited without the Power Running Boards.
Limited Longhorn is the current name. As @SpeedyV said, it was changed from Laramie Longhorn to Limited Longhorn in 2021."Limited Longhorn" was the old trim's name. There also "Laramie Longhorn".
My Limited (not Longhorn or Laramie) had a tag on the leather seats that said thank for you buying a Laramie Longhorn truck.
I would have but wasn't an option way back in 2019
How can you test that?
Aint ever seen mine turn before.
A fully-loaded Longhorn costs more than a Limited (due to a la carte option pricing). I believe that a fully-loaded Laramie might be the MOST expensive non-TRX configuration, as you're adding a slew of options to get there. But I haven't run the numbers in a while.A fully loaded Laramie is just a little less expensive than a Limited with the same equipment...
A Laramie can't get all the options a Limited can. That's why it's less.I've run the numbers numerous times. The optioned out Laramie was always slightly less than a Limited with the same options, every time I ran them.
Interestingly, though, you can configure a Laramie Night Edition with the Off-Road Group. On the Limited, you have to pick one...at least this looks like the case in the (notoriously error-prone) online configurator. @StuartV's response to me triggered my curiosity, and I built a few Rams online last nightA Laramie can't get all the options a Limited can. That's why it's less.
You can't get heads up display or rear view camera (not backup camera) on a Laramie.The Laramie cannot be configured with the adaptive headlights, and it doesn't get the exact same cosmetic treatment (like the same stitching and trim finish in the interior). Otherwise, what options can you not get on a Laramie?
Regardless, my point remains: Other than the headlights, I have configured identical Laramie and Limiteds on numerous occasions, and the Laramie is always a little less expensive. I should also note that when doing so, that has always meant (in MY configs) that the Laramie did not come with a factory tri-fold cover, where the Limited did, because you can't get what I want without that included on a Limited. So, headlights and tri-fold would add to the cost of a Limited over an otherwise-identical Laramie. Still doesn't change what I said. Setup the way I want, as close to identical as possible, the Laramie is less expensive.
I think if you add the technology group option to the Laramie you get the HUD and digital review mirrorYou can't get heads up display or rear view camera (not backup camera) on a Laramie.
Those are both huge options imo.
The soft tri-fold is actually bad, if you have Ramboxes as you can not get an after market cover unless you buy new $350-450 rails from Ram.
Technology package is not available on Laramie.I think if you add the technology group option to the Laramie you get the HUD and digital review mirror
Technology Group [+]
-inc: Head Up Display, LED CHMSL Lamp, Digital Rearview Mirror
It was available on the 2021 and 2022 models.Technology package is not available on Laramie.
It's not available as of last year.It was available on the 2021 and 2022 models.
Probably victims of the chip shortage. I was just going off of what the options were available on the Ram website.It's not available as of last year.
Ask anyone who ordered a Laramie if they could get it, you can't.
