Laramie TPMS
ScarletNight
With the temperature change, my TPMS light went off on one of my wheels. I reset the pressures but the TMMS light still stays on. Is there a reset procedure for this or will it reset automatically?
2019REBEL
ON, Canada
How much over the recommended pressure did you set it. I know on my Rebel I have to go over the recommended by about 2psi and it resets right away, sometimes it takes a 10 mile run to reset them.
jdefoe0424
Illinois
From what I've read of people switching tires/wheels and what not. The TPMS should reset and relearn automatically
Sent from my Moto Z (2) using Tapatalk
Richard320
Drive it.
I was driven mad a couple weeks ago trying to set pressures. It takes forever for the new pressure to display. When it finally looked good, I drove off to run my errands. I doubt I passed a dozen houses before all the pressures changed. Some went up, some went down. So my advice is to drive it.
Grayman5752
Charleston, SC
It can take up to 15 minutes of steady driving above 20 MPH for the light to go out. It usually doesn’t take that long though.
ScarletNight
The recommended pressure is 36PSI and I was at 32 when the sensor went on. I increased the pressure to 34, but the sensor is still on. I will increase it to 36 later and see what happens.
