Most likely you'll need to run a fresh wire up below the console or along the side beneath the scuff plate. Where to tap is a good question. Ram doesn't make that real easy. You can move the 12V power port fuse to B+, which will then leave a female terminal free on the other size. Then you plug in a spade terminal and connect an inline fuse and go off from there. Or get a piggyback fuse tap if you want to have the dash outket remain key-on instead of always hot.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
