Keyed 12v in the back
Luis1275
Anyone know where I can take 12v on key near the rear bench on 2021 1500.
Most likely you'll need to run a fresh wire up below the console or along the side beneath the scuff plate. Where to tap is a good question. Ram doesn't make that real easy. You can move the 12V power port fuse to B+, which will then leave a female terminal free on the other size. Then you plug in a spade terminal and connect an inline fuse and go off from there. Or get a piggyback fuse tap if you want to have the dash outket remain key-on instead of always hot.
