So, my bighorn did not originally have tilt in reverse option for mirrors, because I dont have driver memory stuff.
But I enabled the tilt in reverse options and now have tilt in reverse. However, this was years ago and I've had it disabled because they drop way too much.
Just discovered in J-Scan going thru options, if you go to Door Modules > Configuration > you can change the tilt in reverse value.
Mine was on 40. I went to 20, and its almost perfect for tow mirrors..Might go to 15.
Figured I'd share in case anyone else disabled tilt in reverse because they thought they tilted way too much.
