Is There a Great Looking Wheel Under the Chrome Clad?
Chipman
These are my wheels. I don’t really like them and wonder what they would look like without the inserts. Any opinions. I think they are glued in.
Dr. Jim
I believe I saw where someone on this forum painted the inserts black.
Dusty1948
Rochester, New York
I saw one with the plastic overlay removed. I thought it was pretty darn ugly, but that's a subjective thing. Poke around in the Ram sites. Someone removed them from their 4th gen and had pictures.
Regards,
Dusty
2019 Ram 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 019024 miles.
Love2driveRAM19
Fort Myers, Florida
Well, if they look anything like Silver64's rims he took off the black clad and took the rims with his truck to another level!!!
From this rim:
32418
Silver64 truck:
32417
I want them!!! Unfortunately through RAM they only come in 22's. I have since found out they look like the GMC Snowflake rims.
I am definitely curious what your rims look like with the clad removed!!!!!
George Bednar
Central Illinois
From this rim:
Silver64 truck:
How did he remove them? I havea set and I think these look much better
moosem
Rhode Island
In my opinion, these are the worst looking wheels on the 2019s (Limited 22s are a close second) with or wothout the inserts. The pictures do it no justice, they're even uglier in person.
cra1g
Sherwood, OR
From this rim:
Silver64 truck:
Those aren't the same wheel. I'm pretty sure the wheels on that truck actually are GMC snowflake wheels. On the Ram wheels, the big openings are between the lugs, but on the GMC wheels, the big openings contain the lugs. Also, although I don't know what the Ram wheels look like under the plastic bits, the plastic either sits on a wide spoke, or between two skinny spokes. Either way, removing the plastic isn't going to leave a single skinny spoke underneath it.
32434
busa2009
Atlanta, Ga
From this rim:
Silver64 truck:
these look a lot like these:https://www.discountedwheelwarehous...+Horn+4WD+&vid=81566&t=H&partno=V1182-295824C
swarggs
Pennsylvania
From this rim:
Silver64 truck:
These are GMC replica 22's, not OEM Ram wheels.
Yes they are. When i went to look at wheels it seems the trend is black, black & more black and I wanted chrome because i thought it went better with the billet silver paint. Since the 6 lugs are so new there wasn't really that much out there and the GM wheels fit the hubs perfectly.
mikeru82
The Palouse
Just to clarify, there is no plastic on these wheels. It's chromed metal of some sort. Definitely not plastic though. I don't see how you could remove the inserts without damaging the wheels. But if someone wants to try I won't stop them. I'm curious as well.
21TRX
SICAMOUS
:poop: DT glued on plastic cover below :poop:
Ram's offered this junk since 2003...exposed edge is corrosion prone
