Trippi
I am NYS and my Rebel is NOT commercial
			My payload is 1393 lbsWhat is the payload from the sticker on the driver side door jamb?
It seems I do not have title. I have loan for my truck. Can I find my copy of my title somewhere?I registered my 2021 Ram 1500 Bighorn in June (purchased in MI). I did the paperwork myself, pain in the ***. The only place I found the curb weight was on the Manufacturer's Certificate of Origin (MCO) - which the DMV now has. Title does have the curb weight, 5300ish. So it qualified for passenger plates. I would be surprised if your rebel is significantly heavier.
This is my personal drive and did not say any for business use. The dealer did not ask me if this is for business. I called dealer and they said it is my state law. totally mess upFrom the NYS DMV
When your truck was registered by the dealer they may have requested commercial plates if they thought it was for a business.
I found a curb weight for a Rebel of 5314 pounds.
Pick-up Trucks (Part 106.6 (b) and (c))
You can register a pick-up in the 'Passenger' class if it meets certain conditions, depending on its unladen weight.
If your modified or unmodified pick-up truck has an unladen weight less than 6,001 lbs., you can register it in the 'Passenger' class if it meets the following conditions:
If your modified pick-up truck with an unladen weight greater than 6,000 lbs., you can register it in the 'Passenger' class if it meets the following conditions:
- the pick-up truck does not have any business advertisements
 - the pick-up truck is used exclusively for non-commercial purposes
- the pick-up truck does not have any business advertisements and is used exclusively for non-commercial purposes
 - a camper top having one or more side windows completely encloses the truck bed
 - the pick-up truck has seats, seat fittings, or camping equipment installed in the truck bed
- 'camping equipment” indicates that you have a permanent bed, a permanent stove, or a permanent refrigerator in the vehicle.
It is easy if my dealer is local...I had an emissions compliance issue when I bought my 11 ram used. I was not aware of any problems until I got a bunch of fees in the mail from the DMV. I went back to the dealer to inquire and they told me their paperwork was good and it's a DMV problem. I went to the DMV and they told me the dealer screwed up some paperwork. Moral of my story is, go over EVERY piece of paper and read EVERY word of it. It's obvious that someone, whether you the dealer or the DMV screwed up something. I'm in CT but my 21 crew cab built to serve is registered as a passenger vehicle
its for sure the dealerships issue i would persue it with them and wordt comes to worstIt is easy if my dealer is local...
in new york commercial cant go on many highways and many areas LIKE HALF NYCI guess I gotta check my state’s (California) laws because I was told by all my buddies who have trucks that every truck here is registered commercial if it has an open truck bed. You have regular license plates but technically your registration is commercial. Because I was confused when I originally got mine and it said commercial too. It won’t limit your travel anywhere though. It’s a normal small pickup, no one is going to bother you for using it for personal use lol
Who’s checking that? Like how would authorities know? Also I just googled it and yeah california says all trucks are commercialits for sure the dealerships issue i would persue it with them and wordt comes to worst
in new york commercial cant go on many highways and many areas LIKE HALF NYC![]()
Plates say commercial…Who’s checking that? Like how would authorities know? Also I just googled it and yeah california says all trucks are commercial
DMV should have it. You can re-register as a passenger vehicle if the title shows under 6001 pounds.It seems I do not have title. I have loan for my truck. Can I find my copy of my title somewhere?
I do not know what weight is showed on title, but I believe it should be under 6001lbs. I will stop by DMV next month and just make sure I do not miss any document,DMV should have it. You can re-register as a passenger vehicle if the title shows under 6001 pounds.
https://dmv.ny.gov/forms/mv114.pdf
If the title is over 6000 pounds, you can request and amendment to the unladen weight with the correct weight. Proof would be needed from an official weighing station.
NY DMV Answers
its says it on the plates and all the highways legit say no commercial and if highway patrol legit be waiting for commercialWho’s checking that? Like how would authorities know? Also I just googled it and yeah california says all trucks are commercial
