I knew that was the answer but was hoping it wasnt the answer. Lol. Thanks!Pull the kick panel beside the brake pedal off. In behind there is a ground stud.
Why don't you use the power in the over head console? There is a switched power source and ground. No running wires thru the cab.I knew that was the answer but was hoping it wasnt the answer. Lol. Thanks!
I have a remote button to mute it when it starts going off.Why don't you use the power in the over head console? There is a switched power source and ground. No running wires thru the cab.
