Interior PDC grounding spot?
ekaz
Search isn't being friend and looking for a good ground when I hardwire my radar detector. Using F66 for power but don't see a good ground in the area. Thanks!
I knew that was the answer but was hoping it wasnt the answer. Lol. Thanks!
Why don't you use the power in the over head console? There is a switched power source and ground. No running wires thru the cab.
I have a remote button to mute it when it starts going off.
There are some holes in the beam that holds the fuse panel.. Top left. I installed a bolt/nut there for ground.
I have the same setup. Escort with mute button cord.
