Interior lights (oem to led)
Well, they sure don't seem as bright as led. All of my other interior lights are non led, as well as the cargo lights where the third brake light is
Agreed. We have a Laramie and a Lone Star in the family. The Lone Star with Lasfit footwell LEDS is twice as bright as the factory interior LED footwell lights in the Laramie.
So, are you saying I can replace the stock ones? If so, how is it removed if I may ask, I bought the lasfit leds already just need direction on how to remove the stock ones
If the stock ones are factory LED, I have no clue how to remove them as we just left them that way in the Laramie. I was informed by Lasfit the factory LEDs are an integrated unit in which the LEDs cannot be swapped out.
Okee dokee, that's kinda my impression by looking at the housing and all. Sure wish they would have told me that as they knew my truck was a 2021. Thanks for the help
Hey everyone, well, I have done the back seat dome, and the 3rd brake cargos but the map light is giving me problems big time, got the whole unit out, all trim clips loose minus the area where the sos and assist buttons are!!! They will just not free up to pull the whole trim piece off. Any ideas?
I did give up and plugged everything back in, but thats the clip I am puzzled about and it seems like in the second pic thats one whole molded piece.
@ Chee... The white lens (x2) come off, no need to rip the whole console apart... Replace old bulb with new and you should be good to go...
-=FM45=-
It looks like they do, but a bit timid to pry out, not sure i have a small enough, pry tool....thanks for the info and confirmation
Did you open the sunglass holder and remove the two screws?
Yes, and it has been completely out, disconnected and trim ring clips unclipped minus the one in the pic, going to try just the lans as suggested
Got er done, minus the footwells!! Thanks for the suggestions
I did lasfit ice blue on footwells to see how it would look. I like them so I kept them in. I also did the lower glove box in lasfit white.
Yes, that's why I got them, from your pic on a different thread I think. But I just don't have a bulb cover and bulb, its a whole housing thingy. So I got some research to do
I have the same issue but have not found a solution, have you yet?
Hey, do your Lasfit ice blue footwell flicker if they’re on when you start your truck?
Hmm mine just started flickering on startup last night. I’ve got an email into Lasfit.
Thanks.
