Infamous Whistle Noise PLEASE HELP
It's still making the teapot noise..wiper blades lol... im just saying the newer trucks aren't very good from what I've seen. I loved chevy trucks until my 2019, it was tinfoil thin, very loud going over bumps, bad suspension in the rear felt like you could leave the road, on gravel it sounded like the gravel could be getting in the cab it was so loud. I traded it for a ram because I liked the last one I drove, but it was a 2016. I thought ram would be best after truck of the year bla bla bla, but it's got that whistling noise that drives people nuts, not just me nuts. Don't be afraid to hammer on a vehicle while a salesman is sitting next to you test driving go 75-80 see if it's a teapot. That's all... I'm friends with a body guy so I'll tear apart the post area and the door to fix the insulation that is probably all full of holes. The dealership keeps giving it back to me saying it's fixed, like I won't hear it when I leave the lot smfh...
Again it’s probably your side mirrors, I had that whistling problem on my 2019
I moved the mirrors in and it did absolutely nothing, no change whatsoever. I think it's a hole in the insulation behind the Pilar or in the door.
I found it was the molding on top of the truck. The edge was up enough causing the whistling noise.
I will drive this truck like I'm trading it in because I will in a couple of years... I've had such bad luck now with a 2019 silverado and now this 2021 Ram 1500 longhorn tea pot convertible.
run some tape round the windshield or other areas you think to help locate problem area.
I agree with cerbon, use painters tape to cover a seam, gap, or molding a piece or two at a time. Hopefully you will find it. If not rule things out.
Start by surrounding your windshield.
Good Luck.
I covered the trim above the door and the sound completely went away. I will be replacing the trim, clips and put some very soft hollow trim timing under it. You can tap on the trim and will notice that it seems a little loose like it's not attached well. I put packing tape on mine to keep the air out and it went AWAY. It would start at 65+ mph and drive you up the wall. If you are driving into a headwind, it will start earlier as it simulates a higher speed.
2019 Limited
my 19 had a bulletin I did myself for noise - involved installing a rubber flap between the cab and bed. my truck had them already on the side gaps, this one was for the bottom gap. noise stopped after I put it on
I am having the same issue in my 2025 Laramie. I have noticed when I am driving on the freeway, if I fold in the mirror's the noise is almost gone (still some natural wind noise).
Suggestions? and please no "Get a Chevy, get a Ford". I have had both and all manufactures have issues. Just real suggestions please?
