ironking
Any adjusting of your suspension, either through spacers or struts, is going to limit your travel unless you go with extended travel struts. Spacers limit your up travel because you've pushed the suspension down. Pre-loading struts limits your downtravel unless you have extended length coilovers. When doing extended length you have to change a whole bunch of other stuff too, cause you're stressing UCA's, LCA's, CV axles, etc.
Mid travel kit is my ideal goal, but all I can find at the moment is long travel. May have to get with Dirt King for a custom build if they haven't developed one by then.
You’re partially correct. By going cool over, you’re not going to limit up or down travel, you’re just not going to GAIN travel. They are also normally valved for that specific vehicle or very close.
Going extended travel you don’t need to change all that stuff. Yes you will gain more if you do and could potentially damage things if not careful to over extend. But normally all you need to change for extended travel is UCAs. Good luck with Dirt King. Probably going to be a while. King will do custom coil overs and Fox has extended coil overs out now for 5th Gens. Just bought some to swap my Icons out.
