Impact Driver? or Lug Wrench
blacksheep37
Does anyone else keep a cheapish corded impact driver in the truck for emergencies? I keep one strapped to my storage panels in the bed of the truck just in case. Also means I'm more likely to stop and help someone if I don't have to break my back to do so.
work smarter, not harder.
Threesuns1
Northeastern Maryland
I keep a cordless impact in my truck for emergencies. My old Craftsmen corded impact draw 7.5 amps which is 4.2 amps over the 3.3-amp inverter in my truck. How many amps does your impact draw?
PurpleRT
I keep a 1/2 Milwaukee impact battery operated in the floorbin. Its there if I need it even though I have another impact and other tools for my daily work use in one of the ramboxes.
From my experience, none of the 12vdc corded impacts pack enough punch to break loose lug nuts. So would never waste my money on them. I have a Milwaukee M18 Fuel 1/2" drive in my garage, but it usually doesn't go along on trips.
blacksheep37
I can tell you this one does. I just recently put a spare on because of a flat. Then replaced all my lights going from silver to black.
jkm312
I've got 2, 1/2 inch breaker bars, long ones, with a short extension and the right size deep wall impact socket for the lug nuts on each car and truck. I carry one 1 in each vehicle all the time. They make short work of a stubborn lug nut, are not battery dependent. Money well spent and much more reliable than the lug wrench in with the jack kits these days.
Darksteel165
Massachusetts
That's fine if you got space but knock battery power tools. Tech had gone a longgggg way. It's easy to keep a battery fully, or nearly fully charged for years on a brand name tool, and even it it does drain a little I could still probably change out all 4 tires like like 20 cars easy with an M18 impact with an XC6.0. I also have torsion bars so I know how tight the lugs are going back on. All that fits under my passenger side seat next to the terrible oem jack
Ratchet
Wilson, NC
I keep a decent road kit in the toolbox and its mostly cordless for grunt work. Ran power to it and installed inverter on a remote switch. Threw in Milwaukee multi battery charger and a few other assorted necessary chargers. Factored in the switch so I can recharge on my long commute days just to keep things topped off.
