Hub centric rings????? Fuel Vapors
Wyno
Just got a set of fuel vapors 20x10 -18 offset for my 2021 ram 1500 and they didn't come with hub rings. They are 106.1. My current wheels are wicked offroad 20x9 and they are 106.1 and they didn't come with rings either. Haven't had any problems running without them. With the new wheels was wondering if I should get some hub rings and which ones to get or if there needed at all. Street use only, no offloading. I believe 5th generation rams are 77.8. Any help would be appreciated
Contact Fuel to see if hey offer them. Although, your wheels are technically lug centric wheels. It never hurts to have the hubcenteic rings.
Paulie T
In the past on a sierra Denali I had I put wheels on without hub rings. At higher speeds on the freeway I noticed some vibration in the steering wheel. Installed hub rings and it solved it. My personal opinion is to get some.
Wyno
Any recommendations on a good brand of hub rings to get. And to verify ram 5th gets are 77.8, correct. Thanks for any ifo
CatDaddy66
Yes, 5th Gen Ram 1500s are 77.8. Although I haven't bought them. US wheel adapters seems to be a really good brand and they're made of aluminum unlike some other brands I've seen that were hard plastic.
Rick3478
NW OH
Your third party wheels come without rings because they don't know what you are putting them on. The hub holes are machined large enough to fit over anything on the market, and you are expected to add centering rings to fit your vehicle. Knowledgeable providers like TireRack.com offer wheel packages that include the correct size rings. Failing that, find out the size of your hubs and wheels and buy a set of rings somewhere. I prefer metal rings, but plastic is okay. Rings assure that wheels are perfectly centered before tightening the lugs, and arguably might hold things in place if you hit something *really* hard. I would not consider installing your wheels without them.
Morenar
West Central Florida
When I bought my fuel wheels. The boxes had several hub adapters in them. They were green for one size and orange for another. Believe the green ones were used.
Shark875
Should be a 77.80 and 106mm And yes I would recommend buying them, I mean you can get a good set for what under $30 tops and they will make sure your wheels are perfectly aligned. Definitely worth it !
