how to start truck if key fob bettery dies
Page 24 of the owners manual covers this. It's not even that deep, and has been covered already on this forum as well. You just simply hold the front of the fob (the lock button side, not the keyring side) against the ignition switch and push the button (with your foot on the brake, as normal)
Like some, I didn't read the manual cover-to-cover and didn't see any previous mentions of it so I'm thankful. Per @riccnick I went and looked in the manual (in mine it's on page 27) and it says
In case the ignition switch does not change with the push
of a button, the key fob may have a low or dead battery. In
this situation, a back up method can be used to operate the
ignition switch. Put the nose side (side opposite of the
emergency key) of the key fob against the ENGINE
START/STOP button and push to operate the ignition
switch.
Can you drive it still. I was under the impression that the 5th gen needed the key in the vehicle to actually use it. Sort of if you start it but walk away with the key. Will it still operate or will it just shut off when you try to drive?
Key?.. the Fob will still be in the truck, you're just putting it against the push button
Rambuzz mentions that the owners manual mentions a screw to remove in order to access the battery. I noticed he has a Laramie key fob in the video. On my same year Big Horn I did not have the push button start like his and the fob for that has a screw. I'm guessing the owners manual forgets to mention the two different fobs.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 011847 miles.
You can drive the truck without the fob, as long as it's running already. Once you shut the truck off and need to restart it again, that's where you need the fob again.
