ramButz
of all the stuff that is posted here i havent seen what to do in this situation,thought i share it with some of who a still finding out about our new ram!!
			In case the ignition switch does not change with the push
of a button, the key fob may have a low or dead battery. In
this situation, a back up method can be used to operate the
ignition switch. Put the nose side (side opposite of the
emergency key) of the key fob against the ENGINE
START/STOP button and push to operate the ignition
switch.
Can you drive it still. I was under the impression that the 5th gen needed the key in the vehicle to actually use it. Sort of if you start it but walk away with the key. Will it still operate or will it just shut off when you try to drive?
