Jason Allan
Looking for any information on how to run wires from inside cabin of my 2019 ram 1500 through the firewall into engine bay to the battery. Also looking for information on how to access fusebox under steering wheel.
I went through the large grommet in the upper left hand corner behind the steering wheel, it comes out at the top of the engine bay right behind the battery. Panel has two screws at the bottom, one on each side that need to be removed. Then I grabbed from the bottom with one hand and the top with the other hand, pops right out.
Very easy for both. To get to the fuse box you just remove the trim piece under the steering column by removing the two bolts and then pulling until the clips release. Firewall access is easy via the grommet jloop mentioned. See pic below. Poke a hole whatever size you need. I use a little electrical putty to fill in around the wire/hole to make it water tight.
awesome thank you Patsy1099!! one other thing .... can I poke a hole anywhere through that grommet without fear of damaging anything? Also do you have any idea what size of circuit tap I would need (what size of fuses they are in that panel? I'm trying to tap into an accessory fuse.)
